Hijack shows the "raw" capacity as reported by the drive and doesn't care what partitions are set up as I understand it.
Emplode shows the partition capacity and this is probably wrong.
So I would say from what you're telling us, your build is not ok.
run these two commands:
fdisk -l /dev/hda
fdisk -l /dev/hdc
Edited by Shonky (28/03/2010 21:53)
Edit Reason: corrected type in command 1 != l but looks the same in the post edit font...
