And here is an example of something you want to avoid: claims 1920x1080 native resolution, but only allows 1360x768 max digital input from a PC... they're probably lying about the native resolution.
Here's a review on this set. It claims that this is a true 1080 set. If you connect to it with your PC via HDMI than you can use the full resolution. Like Andy's Sony I think the specs about proper input resolution for the PC reflect bandwidth limitations of the VGA analog input and not the true native resolution of the panel.
http://www.i4u.com/full-review-309.html
No matter where you might be, there you are.
