The only reason for it is if you believe the Bible literally, which is itself absurd based solely on the fact that it has so many internal inconsistencies, from contrdictory viewpoints, to historical inaccuracies, to "plot" points changing, to inconsistent internal logic.
You'd think that just the two different versions of creation in the Bible would be enough to blow the whole "the Bible is the literal truth" argument out of the water without anything else...
And that doesn't even say anything about how many different versions there are of the Bible itself! There's even a "parallel Bible" in print that has 4 different versions side-by-side-by-side-by-side.
