So, how about you decide the final assignments within those constraints?
When I get the bluetooth dev board working again, I will try to go with this (jury is still out until I actually implement it for sure though):
1 - Pink - Originally level - Now IISD1 (empeg) <-> SDIN (bluetooth)
2 - Grey - Orignially signal - Now IISW (empeg) <-> WS (bluetooth)
3 - Blue - Power Ant (not connected on wiring harness)
4 - Black - 0v (unchanged)
5 - Brown - TX (unchanged)
6 - Red - RX (unchanged)
7 - Purple - Orginally no connection - Now IISC (empeg) <-> SCK (bluetooth)
8 - Blue - 12v (unchanged)
Also, the empeg has 5V available internally, so if we feed that out the tuner connector, then there's no need for any extra voltage conversions.
But since I'm still leaving 12v, ground, TX, and RX unchanged, that leaves only one wire left for that 5V run:
... And that one isn't connected to the wiring harness. There's no pin on the docking connector for it. And I can't hijack the existing 12v blue wire because that's the one that comes out the dock connector for the Amp Remote wire. So I think we're stuck with our own power supply.
